i'm starting to build alil system for my civic, right now i have a Panasonic DF903U head unit with 6.5" alpine type S in front and 5.25" in the back. the sound that comes out still is very nasty, maybe due to the old stock wires i use. now i just got a Alpine MRP-F240 4-ch. Amp with these specs... used to power the four speakers.
General Specifications
» 40 watts RMS x 4 at 4 ohms
» 50 watts RMS x 4 at 2 ohms
» 100 watts RMS x 2 bridged output at 4 ohms
» 2-, 3-, or 4-channel output
» 4-ohm stable in bridged mode
» Tri-way capable (Tri-Way Crossover required)
» selectable high-pass/low-pass crossover at 80 Hz, 18 dB/octave (2 separate crossovers, one for channels 1 & 2, another for channels 3 & 4)
» subsonic filter at 15 Hz for channels 3 & 4
» tuned Bass EQ (0-12 dB bass boost at 50 Hz) for channels 3 & 4
» preamp outputs
» MOSFET power supply
» STAR Topology (minimizes internal noise and prevents ground interference)
» speaker- and preamp-level inputs
» gold-plated screw terminals
also i bought 2 10" kicker c10 subs. it was buy one get one free at CC. heres the link for them... http://www.circuitcity.com/ssm/Kicker-10-Comp-Subwoofer-05C104/sem/rpsm/oid/117478/catOid/-13641/rpem/ccd/productDetail.do
anyways i have some questions, i'm trying to find an amp for the subs. budget is pretty low... trying to find something for about 100. any recommendations? i think they need 150 rms X 2 at 4ohms. not sure... i'm new to this stuff... i'm actually looking at a Kenwood Kac 7202.... maybe it works good with them? i don't know...
also another question, the alpine amp already has a installation kit wit the wires and everything, do i need to buy another kit for the amp thats use to power the subs or can i use the same kit. i don't have the specs for he kit for alpine amp yet. So i'm researching now. heh... thnx
» preamp outputs
