Newbie Question...
POWERD.by.VTEC
ok guys now i know i might get flammed for this but its just something i need to know
i did a search and came up with nothing
i wanna know what exactly a "computer chip upgrade is" for a B16A
-thanks in advance-
4thengine
Acne Records Rep.
Just what it sounds like. It's an upgraded chip in your ecu. Where did you find this?
it increases the timing curve and makes your injectors squirt more fuel
Mr. Lin
Admiral Ackbar
Added juice=more power... for those of you who couldn't figure it out...
hondaexboy
if ur good u can basically do the samething with a piggyback system on ur car, but u gotta be knowing what doing
Martin Racing Design
FKA Carbon Creations
no thanks for me. Inefficient and a ricer mod imho. If you have the engine to justify the extra fuel/timing, then by all means... but if your stock with a chip... dieeeee
4thengine
Acne Records Rep.
If you're stock, there's no reason to change the chip. Most companies that chip your ECU require a mod list also, so that they can match the specs on the chip to what you've done. A programmable ECU or piggybacks are a wiser (and probably cheaper) way to go unless your mods are completely finished (as if that ever happens.)
