ok guys here is a theory build and i decided to see what yall think about it feel free to recomend parts im still putting together a final parts list
but i want to build a high compression ls vtec with forged internals and shoot it with a 175hp shot
this is the current parts list
updated parts list i decided to go all out
im also going to get the block bored 20 over and have it honed
p&p----------------------------------------------n/a
b16a head--------------------------------------n/a
edelbrock victor x intake manifold----------n/a
edelbrock 65mm throttle body---------------n/a
adj fpr-------------------------------------------n/a
act prolight 7.5 lb flywheel-------------------n/a
act stage 2 clutch------------------------------n/a
s1 lsd trans-------------------------------------n/a
hasport billit aluminum mounts----------------n/a
__________________________________________
dsm 450 injectors------------------------------used 50
skunk2 stage 2 tuner series cams----------used 250 w/gears
__________________________________________________ _
ls block w/ crank and caps and rods-------150
dual valve springs and tit retainers---------319
bronze vavlve guides------------------------89
custome exhaust piping 2 1/4"-------------100
magnaflow muffler---------------------------68
nx wet kit--------------------------------------150
obx high flow catylytic converter----------60
golden eagle metal head gasket -----------99
wisco forged pistons 81.5mm-------------430
walboro 255 fuel pump---------------------100
golden eagle ls vtec kit----------------------175 shipped
eagle h beam rods w/ arp rod bolts-------310 shipped
hytech replica header long tube-----------390 shipped
arp head studs-------------------------------139 shipped
comp clutch stage 4 6 puck----------------355 shipped
TUNING____________________________________
dyno tune------------------------------------150
p28 ecu chipped/ socketed---------------175
obd-obd1 ecu jumper----------------------30 used
obd1 b series vtec dizzy------------------65 used
obdo-obd1 dizzy jumper-------------------15 used
misc------------------------------------------150
grand est total--------------------------------3,819
