no dome light after deck install?
beany_
after i installed my deck in my 98 ex, i noticed that my dome light doesn't come on when i open my doors now. but if i manually turn the light on it works. any ideas?
cujo613
green with black
green with red
jump them together
AND QUIT MESSIN WITH s**t YOU DONT KNOW ABOUT
U LUCKY YOU DONT HAVE KEYLESS ENTRY
Genuine Rolla
Its PETEY PETE, y0!
Alright...when you take out the stock deck...that is what controls the dome light...when you remove it and put in a after market deck, you will no longer be able to use your dome light when you open the door, but you still can maually turn it on. I havent heard about this "jumper" thing so...im not sure if thats correct.
civic98mi
It is correct, and it does fix the domelight problem, but I haven't tested it on a civic with keyless yet. You're right on the wiring going through the factory radio that controls keyless and dome. I'm an installer at Circuit City, and I've done this fix about 7 times so far on civics....works every time. What sucks though is that the only 2 civics that had keyless, they never worked properly to begin with, so I couldn't test to see if this fixes the keyless not working or not. Oh well.
BTW, it is the bright neon green plug that used to plug into the OEM radio. The old method is to use a "T" harness from Metra to keep the factory radio plugged in and hanging behind the dash. This is just a pain in the ass and impractical.
The 2 wires are green/red and green/black. Just solder them together and domelight will work again.
K2_civic
Fo-drizzle!!!
beany_ said:
^ thanks for the info but too bad ur a d**k.
He told you what to do, and it was simple, and i think he had every right to be a d**k, if you help someone, then that means you can be a d**k for the day
Genuine Rolla
Its PETEY PETE, y0!
:rolf:
absolutely rediculous...hmmm...so if i spice in some wire to those wires that were indicated in the earlier posts to make my dome light functional again? I wish i knew that a few years ago...but, i'll definitly be doing this as soon as i can...!
beany_
^ i guess everybody is entitled to there own opinion.
And thanks again for all the help guys. I appreciate it.
K2_civic
Fo-drizzle!!!
Bump for being polite
cujo613
wow
I guess i didn't have my coffee that morning
lets try this again
behind your deck there is a green plug that you didn't use to wire up the deck
if you jump the green with a black stripe and the green with the red stripe together the domelight will work
I wasn't being a d**k
thats how you retain he domelight function in 96-98 civics
Akiahara96
back!
hahahaha. i'll have to remember to quote you every time someone tells me i'm being an ass if i answer a question. :lol:
Genuine Rolla
Its PETEY PETE, y0!
sweeet..thanks for the info! i'm as much apprecciative as the OP probably is.
