no fuel???
omgimanub
i have a 02 civic si and my car died the other day, i found i wasn't getting fuel so i replaced the fuel pump.. the fuel pump wasn't getting power so i replaced the fuel relay now my pump is powered but my engine still isn't getting gas im running out of ideas so any help would be appreciated
1993civicDX
check the fuel filter?
if you're fuel pump primes when you turn the ignition on but don't start the car it's fine. id say fuel filter then injectors. should be able to run on a bad injector but its worth the time to check them out
just prime the fuel filter a few times then see if there is pressure by removing the screw on top of the fuel filter, little gas should spew out so make sure you have a rag ready.
