Hey guys, just did a b18b swap, we left all the wires connected to the b18, i used the ecu which was running the b18 in the previous car, i have no tach, no speedo, no gas, i only have temp.. what could this be
what fuse could it be though? like the only gauge that works is the temp, which fuse should i look for, for the gas - tach - speedo ( by means shouldnt the tach and speedo be wiring into the motor?) and not a fuse? correct me if im wrong
umm no fuses help control electricity and electricity controls the lights...... i burned out a fuse doing a gauge cluster swap from 96-00 to an 04 ex cluster and all the lights still worked but my odometer speedo tach and heat gauges did not work on either cluster until i found the fuse.from a quick google search here is a diagram showing the fuse locations and there related number slot
