kenbruce25 New Member Dec 18, 2015 #1 I have a 1994civic 2 door hatchback with no power to the fuel pump
HeX Authoritah, respected. Staff member Registered VIP 5+ Year Member 10+ Year Member Dec 26, 2015 #3 How did you identify theres no power to the fuel pump? Did you check the fuel pump relay as well as the fuse?
nd4sped Moderator Registered VIP Registered OG 5+ Year Member 10+ Year Member 15+ Year Member 20+ Year Member Dec 26, 2015 #4 You should recieve battery voltage at the pump connector when you turn the key to the on position for about 2 seconds then go to 0v. During cranking you should get battery voltage though (12v+)
