Hey guys...I've searched this a few times to no avail. My reverse lights are inop at the moment. I checked the bulbs, fuse 15 is fine, and I just replaced the reverse light switch. What other options do I have? Ugh.
Well if your car was swapped, then the first thing i would do is check to see if the reverse switch on the transmission is plugged in, if it is follow the wires and see where they go, basically in the guide it says to run the wires from that transmission switch to a 14 pin white connector in the center console, so check to make sure the p.o. that did the swap hooked it up properly. I'd assume that connector is under the ashtray/cig lighter console, if the connector is gone then look for hacked up wires lol. After you've confirmed everything is hooked up properly, check to make sure you installed that reverse switch properly, you can do this by unplugging the connector at the trans, and checking for continuity while the trans is in reverse. after you've confirmed that the switch, the wiring, the bulb, the socket, the ground, and fuse are all good then you can start ripping everything apart to look for a broken wireHey guys. Still no reverse lights. I found a write up on Hondatech explaining the specifics of rewiring a reverse light switch during an auto/manual swap. Guess I should've mentioned in the beginning that my car is such a car, an auto/manual swap. Here's the writeup.
http://www.honda-tech.com/showthread.php?t=2090074
Now, it says rewire it using the wiring harness connector from an the auto car. But I don't have such a harness. What are my options? Does that make sense? Thanks
