No spark, no voltage on TEC coil
mastahh5
Hello,
I know that someone who put first post with support request is not well liked, nevertheless I would like to ask You for help, because I saw a lot of people in other topics with huge experience.
My Honda 6G, sedan, 1.4iS Gasoline + LPG, D14Z2 has no spark.
Symptops were: one day I observed irregular work of engine (check engine start to blink). After few kilometers, I stopped, I kept motor running working on neutral and it suddently switched off. After this I cannot start again.
I found one high voltage cable broken. After this I replaced cable and broken Igition Coil Fuse (no. 9, 15A).
After this I cannot start the car. I have no spark. I have voltage on power yellow-black cable in the connector plug just before the distributor, but I don't have voltage on coil.
I dismantled coil, supplied directly with battery + bulb and looks OK.
Voltage "disappear" in HITACHI E12-303 module in distributor, but now I don't know if:
- module is broken
- module doesn't give voltage, because of something?
What I should check? I will be grateful for any support.
