Normal little engine shake while idling?
98civex
98 civic d16y8
During idle you can see the engine shaking a bit at the distributor cap. Took a video but the frame rate is off so it's captured in a slow motion type of movement
Check your motor mounts for rips or damage
98civex
They all looked good visually
Esotericimage
Taking an H-T break
All of em? the rear one is one to look at.
have someone in the driver seat, keep the foot on the brake and slowly add throttle and let out clutch to grab a bit.
If you see the engine moving alot more than what your looking at, then your rear mount is bad, If you see the side mounts move, then you know it both back and sides
98civex
I know I had the back one replaced a while ago, isn't that the transmission mount there?
So that shaking isn't normal?
Esotericimage
Taking an H-T break
I dont see any shaking in the video.. All I see are spark plug wires moving.
Show me the engine shaking
98civex
In person the engine shakes and it's only noticeable at the distributor cap.
Trying to capture it moving slows down the shake and gives it that slow mo look like the video I posted
But in person it's a faster "movement"
Esotericimage
Taking an H-T break
Try the method i listed above. If the engine moves, then you know you have issues.
I dont see anything going on.
