OBD1 gsr swap into EK
EK Devil
I was wondering what will i need to wire up and change out if I was to swap a OBD1 gsr motor into a 97 EK...im planning to use the EX harness for the gsr motor...any help and tips would be appreciated or links...thanks
AliasNeo
youl have to extend wires. for the obd2 chassis part with obd1 engine( might not pass state emissions if they're strict about it) if you use the obd2 harness, use obd2 injectors, and distributor. you can get obd2 to obd1 conversion harness to run the obd1 ecu. or you can go further and replace the oil pump with the obd2 one and run the obd2 ecu
