DIY: Wire 99-00 OEM Fog Lights /w Parking Lights
This DIY will show you how to wire your 1999-2000 Genuine Honda OEM Fog Lights to turn on with parking lights as well as stay on with low/high beams. The fog lights should also blink with the flashers when arming/disarming your alarm (as long as the switch is on).
Applicable Years: 99-00 Coupe, Sedan, Hatchback equipped with Genuine Honda OEM fog lights.
Difficulty: 1 out of 5
Estimated Time: Less than 30 minutes
Required Parts: This can be done with the fog lights installed or not installed since you're messing with wires that already exist on the car either way.
Required Tools:
- Small jewelers flathead screwdriver
- Regular screwdriver to remove underdash plastic pieces
- 10A mini fuse
Additional notes before we begin:
- The previous How-To recommended to disconnect the negative terminal on the battery since you'll be dealing with electrical stuff. However, I didn't and did NOT run into any problems.
- Please keep in mind you CAN do this before actually installing the fog lights. But in order to ensure you did it properly, they obviously must be installed. This How-To was written with the fog lights already installed!!!
- I do NOT take any responsibility for mistakes or problems you run into after completing this How-To! If you have any questions, don't hesitate to ask and I (or anyone else) shall do my/their best to help out.
- Please please PLEASE read the additional/comments at the bottom after all the steps!
Step #1:
Remove the plastic underdash piece underneath the steering wheel as well as the steering wheel column cover. Keep in mind that you will have to tug a bit to remove the underdash piece and to be careful when remove the steering wheel column cover. The clips tend to break very easily. Now in order to remove the 2 plastic pieces, you will need to remove the screws circled in red in the picture below:
Step #2:
With the 2 plastic pieces off, remove the 2 white plugs circled in red in the picture below (there are little tabs you have to push in, in order to pull them out):
Step #3:
Unwrap the black tape around the wires between the 2 plugs.
Step #4:
Now use the small flathead jewelers screwdriver and carefully unclip both ends of the red and white wire from each plug (it is also the only wire holding the 2 plugs to the rest of the harness). You should have the following when you are finished:
Step #5:
Again, using the small flathead jewelers screwdriver, carefully unclip both ends of the red and green wire from each plug. I am holding the wire with my thumb and pointer finger in the following picture:
Step #6:
Then continue to take the red and green wire you just removed and put it in the slots where the red and white wire originally were.
Step #7:
Then take the red and white wire you removed in the beginning and put them into the slots where the red and green wire were.
Stop and take a moment to think:
Basically, you are swapping the red and white wire with the red and green wire.
Step #8
Now go to your underdash fuse box and look for the taillight fuse. It should be a 7.5A fuse. Replace that with a 10A fuse.
Step #9:
Plug the white plugs back into the steering wheel column and give it a test. The fog lights should now work with parking lights as well with low beams and even high beams!
Step #10:
If all is well, reassemble the underdash pieces and enjoy .
Additional Notes/Comments:
- BEWARE! In my research previous to doing this How-To, some people have found that when arming/disarming their alarm with the fog light switch on, they have blown their instrument/cluster fuse. I previously noted before I began this How-To that when arming/disarming your alarm with the fog light switch on, the fog lights WILL blink as well when the corner lights blink.
Required Tools:
- 10A mini fuse
Step #1:
Step #2:
Step #3:
Step #4:
Step #5:
Step #6:
Step #7:
Step #8
Step #9:
Step #10:
