Oh yeah*head bangs*
radarblips
WELCOME TO VUVLAR
Normally I wouldn't have gotten all Sony audio equipment, but I got a really good deal on everything. Not bad for only having 30 bucks invested into it, excluding the Sony head unit, hopefully sometime next week I'll have the front speakers replaced. Not a excessive amount of bass, but enough for me.
Trunk shot
The new 6x9s
The head unit
What I'll be using to power my front speakers
Svr_Civic
dont try, dont fail
LMAO AT UR TINY SUB !! naw jp good pic up...i picked up 2 mtx thunder6000s 15" subs for 100 bucks...with box and 1000 watt amp..... =)
radarblips
WELCOME TO VUVLAR
15's :shock: I don't need that much bass for the music I listen to =)
Jezek
No Avatar FTW.
sweet...sony amps have failed me tho so i frown upon all Sony car audio products :???:
J32a2OwnsU
Resident Old Man
Is there another subwoofer on the other side of that box?
that box is WAAAAAAAAAAAAAAAAAAAAAAAY to big for that speaker.. I'll bet that bass sounds muddy as FOOK.
Cut that box in half ASAP.
Nice pick up for cheap though!!! =)
radarblips
WELCOME TO VUVLAR
The box is cut off a couple of inches past the sub from the inside 8) It's the factory system from the Xplod edition Ford Focus.
J32a2OwnsU
Resident Old Man
whew............... =)
J32a2OwnsU
Resident Old Man
radarblips said:
8) btw does anyone know how to wire up two amps in one car?
same as you would one. but I would put another fuse in line for the other amp.......
get a splitter and wire the power splitter in the trunk....
radarblips
WELCOME TO VUVLAR
So....could I just split off the power like you said, split off the remote, ground it and what about the rca's?
Shiznit
Stickin it to the Man
the only thing sony in my car is the 1200 watt amp. mind you its not 1200 watts, probably not even 1000. but it still makes my type r's hit like crazy
Shiznit
you cant split the power cable, you threaten your amps if you do that. you can however split the rca's and the remote
J32a2OwnsU
Resident Old Man
you can split everything.
so you should run a 2-4 guage from the battery to the trunk, get a split fused power distribution block to split the wire and power your amps, the remotes can go to whereever teh original remote came from.
radarblips
WELCOME TO VUVLAR
Thanks man, I'm gonna go pick up a power distribution block tomorrow, now I gotta wire the front speakers all the way to the amp in the back, great :lol:
J32a2OwnsU
Resident Old Man
What is your total wattage RMS to the amps? If you are running under 1000W RMS, the 4GA will do just fine. be sure to get a split fuse PDB so each amp will have its own fuse to protect it.
And have fun running speaker wire all the way up front to the door speakers...
oh and I would also get at least a .5 farad cap.. With 2 amps, and your lil honda altenator, your light will be dimming on bass hits and intense audio passages... =)
J32a2OwnsU
Resident Old Man
dramysx said:
box is rather large
ehh..........................ummm......................
radarblips
WELCOME TO VUVLAR
oh and I would also get at least a .5 farad cap.. With 2 amps, and your lil honda altenator, your light will be a dimming!!!!
It's under 1000 for sure, thanks for the advice man, you've been a lot of help.
cujo613
Not to support wal mart, but they have a dual amp kit made by scoche with all the distros for like $30 bucks. Way cheap if you are running just a little something. You hit up a shop your fused distro will cost that alone
Genuine Rolla
Its PETEY PETE, y0!
it looks like it was subbox made for a truck. I cant wait to get my system all together finally. 2 Infinity Reference 12's with a profile amp pushing 480 watts rms total =)
