oil adapter for oil pressure sensor/turbo feed
o0kuam0o
Master of Ceremonies
ok, so i just bought a used turbo kit and all i need is the adapter that goes into the motor that sends the oil out to the turbo.. i also need a flange for the oil pan and then my kit will be complete.. where can i find these two items? thanks..
mitch
io_303
NIFOC
the adapter can be found next to the gauges at autozone, as for the bung i dont know
lkailburn
stealthmode sells the t-fittings off his site for the oil feed. i think its www.stealthmodeperformance.com
for the pan you can go to a hardware store and buy one of those threaded tube fitting things. one end is threaded, the other end has the rigid thing that you clamp the tube onto. all you have to do is figure out what size your drain is and then find the right part. then drill (and tap if possible) the hole into the pan and weld or jb weld it in.
o0kuam0o
well all i need to find now is the bung to weld into the oil pan
Handlebars
None Taken.
i used a radiator hose bung, a 1/2" ntp fitting to a 3/4" hose end, and welded the threaded part into the oil pan.
