oil catch tank
SickEk
found a few catch tanks for around 40 shipped. was just wanderin if it would be a big requirement on a d16y7 with a small turbo kit.
Steven.
Formally Green 91
i have a oil catch can on my NA DOHC ZC.
SickEk
urs on the front of the valve cover also?
Steven.
Formally Green 91
no, the white hoses
SickEk
main reason i wanted one was to relieve the oilpressure cuz another forum said that there valve cover was leaking cuz of turbo pressure. im new to this so im figurin out what i can still
Phantom Civic
Never Satisfied
The pcv valve shuts under boost, closing the vent. If you have a breather or something of the like on the VC then it will still relieve some. Thus the catch can. It doesn't close under boost and allows a constant vent.
Not to thread jack but how many of you are running an open vent? I'm thinking of putting a hose on the VC and where the PCV valve is and running it to the ground.
EGlude Attitude
All Motor Militia
I have my catch can routed with the lines from the breather and PCV both to the catch can, with a breather filter fitted to the top. This way once it is turbocharged any thing that would blow by through the PCV or breather into the manifold is instead caught in the catch can and then the fumes vented to the atomsphere.
Their are alot of ways to setup catch cans, pretty debatable. Tons of threads on Honda-tech about it. On the B-series people remove casting plugs on the back of the block and run fittings to vent crankcase pressure to the catch can, but to help pull the fumes out they also use a vacuum source that never sees boost, for example the intake tube on your turbocharger. When spooling it is a constant source of vacuum and will never create positive pressure, thus helping evacute the crankcase more effectively.
For more information:
http://www.honda-tech.com/zeropost?cmd=tshow&id=1490117
