Oil feed line....
Sleeper
92 4doorSleeper
Is where I have my oil feed for turbo an ok place?
bcivic94
were do you have it running it from? do you have it running from the back of the block were the oil pressure sending unit?
Sleeper
92 4doorSleeper
BUMP damn it... i need this question answered ASAP before I start the car
bcivic94
hmm never saw someone run the line like that. did it come in a kit? or did you just choose to run it from there? most kits have the feed line including mine have the feed like coming from the back of the back of the block and use a fitting that replaces the oil pressure sending unit( most have a outlet for the sending unit also. I am not how the pressure is coming out the head where you have it. I know they use the back of the block because its ment to read oil pressure so there is deff pressure running threw the line. when coming from the back most kits tell you to run to the right of the motor when looking at it head on.
Sleeper
92 4doorSleeper
Well I saw a plug there... pulled it out & oil pours out like there was no tomarrow....
bcivic94
you can try it out, Iam not sure if it will work. it very well might, but i havent seen a setup yet that used that plug for an oil feed line. if i were you i would use the pressure sending unit hole in the back of the block, since that is a proven way to lube your turbo.
Shiznit
Stickin it to the Man
if oil is pouring out then i dont see why it shouldnt work. does it still pour out when the car is on?
bcivic94
if you pull the plug on your oil pan oil pours out, but theres not enough pressure to send oil to the turbo. iam just not sure that there is enough oil pressure coming from there. like i said i have never seen a kit use that before, and iam sure if it worked someone would have used it since its easier then going behind the block.
$lick Rick
TEOTWAWKI
hmmm... it's really close to the vtec solonoid which could cause problems with the oil pressure in the head and cause vtec to not engage...
Mr.Luder
SSM EP3
yea i think that oil is for the vtec...mite have vtec issues!
$lick Rick
TEOTWAWKI
it also could starve the head for oil and create problems there as well.
vtec heads need all the oil pressure they can get :lol:
Shiznit
it would probably be safe to use the normal plug located in the rear of the block
$lick Rick
TEOTWAWKI
mymmeryloss said:
who needs vtec?
its turboed...
lol
chris
the entire reason that toda makes "vtec killer" cams exhist is to keep a steady oil pressure in the head and they are usually combined with boost.....
mymmeryloss
RHD is where its at
you know i was just messing around.
god, ppl take me way too serious around here
forgiveness acceted in advance..
chris
mymmeryloss
RHD is where its at
by the way, i would not have a vtec motor if i had turbo..
just my $.02
chris
$lick Rick
TEOTWAWKI
chris
omfg did you even read my post?
I WAS f**king AGREEING WITH YOU......
but now.... now i'm inclined to disagree, mostly because of your lack of common sense
mymmeryloss
RHD is where its at
i couldnt tell you were..
i accept you accepting me feeling like an ass...
chris
