I Need Some Help Installing A Mechanical Oil Pressure Gauge On My D16y8. Ive Searched All Of The How To's And Diy's And I Cant Find A Good Walkthrough. If Anyone Can Help I Would Appreciat It.
well with your gauge you probably had a small white tube that goes from your gauge to your sender , unscrew the oem sender and you also probably have bolts with your gauge find the one that fits in the hole and srew it there, then the rest it probably a ground wire and the 12volt wire if you got a light into it
