Oil Pressure running to turbo.
hundredwatt
How much oil pressure should i be running into the t2/t3 turbo? I ran a 3/8 line to the turbo which I'm sure is too big. what do i do? It's smoking like a b***h, and i'm thinking it's from the turbo, leaking oil, but i'm not sure. The seals are new in the turbo, and it spools good and spools fast. I'm just using a lot of oil.
EGlude Attitude
All Motor Militia
Have you checked the charge pipes for oil?
A friend of mine with a turbo D ran too big of oil lines and blew the seals in the turbo. Using a flow restrictor will fix that.
slowhatch
torque?
or the correct sized line; -3an.
1992_HB
better off to get a restrictor and have one on hand ready to put on incase its to high pressure. I cant remenber how much pressure is need im thinkin like 13 psi.
ryan89crx
Spoolin single cam!
get a restrictor. bushing-type turbos only need 15psi of oil pressure. a stock Honda can put out upwards of 60 at WOT
also check the routing and size of your return line. make sure it isnt kinked or kind of "U" under the actual oilpan flange. also the minimum ID of the line/flange should be 1/2"
hundredwatt
Where do I get a restrictor? is it adjustable? and do I just put it inline with the oil line? Yes the charge pipes have a little oil in them. and my spark plugs are saturated in it. My friends D puts out near 100 psi at wot. I was running some cheap ass oil line into the turbo and it blew on me, I replaced it with some better line, but my engine bay is covered in oil. What is the best way to clean this s**t out? I've never had so much oil everywhere. One things for sure, this s**t ain't rustin'.
deftone
w3rd... i used to run a -4an and my s**t would smoke like crazy. replaced that with a -3an and now its fine
forcdincivic
Needs More Snail
yeah i just did my turbo install this weekend and i had a -3an to the same return like -3an, i was told it would be okay but it smoked like a mofo and burnt oil but i just got a 1/2 inch line and new fittings so i hope this works out....
forcdincivic
Needs More Snail
I have a -3 line with restrictor and 1/2" drain.
Do you think i should get a restrictor....i mean is the pressure that much for the turbo to handle properly? (without leaking out the seals or something)
Handlebars
None Taken.
you want a restrictor with a .060 diameter. function 7 sells a nice billet one, but you can buy a cheaper one from http://www.mcmaster.com, just search 'restrictor' and order the .063, its close enough.
ryan89crx
Spoolin single cam!
thats the one i use, works great!
deftone
if you have a -3an feed line you dont need a restrictor
Handlebars
None Taken.
some people do, it depends on the turbo, my friend had a -3 and it was still smoking, he threw on a restrictor and it fixed the problem. especially in older turbos with more shaft play, having a restrictor does reduce oil consumption, even with a -3 line.
ryan89crx
Spoolin single cam!
also helps with knockoffs, which are notorious for weak seals.
i use the Function7 on my XSpower t3, and its been working great for 2 years :thumbs up
forcdincivic
Needs More Snail
I have a garrett t3/t4, i put the lines on and its not really smoking anymore but if it starts to at all im definetely going to have to get that restrictor
stolle
i dont really think that the size of the line matters in the case of oil pressure the bigger the hose would just mean more volume but the same pressure. i use 3/16 brake line for my oil supply with no restrictor and it works fine a restrictor is a good idea though, as most of the time the addition of a turbo will actually lower your engines oil pressure mine with a turbo is around 70psi but without is around 80psi and as stated above the seals on a turbo arent designed to handle that much pressure.
