ok so yeah im a noob with alot of questions..
vlc92189
Okk! my friend gave me a 1000 w audiobahn sub.. 12" and a 800w amp. now what will i need to hook it up? how do i do this? and it seems like.. when i turn the i think its calld " treble" until its balance theres like static in the car.. or when i turn the bass up.. but theres like static in every speaker... sorry but yeah i suck at electronics:-/
snoob
9k RPM and 1+ Lateral G
i'm confused... is the amp and sub in your car already or are you just asking about your old stereo? i'm not to knowledgable on stereos myself but i know a little.
if you want to know what you need to use the amp and sub... you're going to need a head unit to control the sub. you'll have to run a line from the head unit to the amp, i believe its called an RMA line... and you'll also need a power line run to the amp from the engine bay... and of course find a ground.
its not as hard as it sounds.
vlc92189
i know it shouldnt be.. i have the amp.. subs.. and head unit... but what i was asking was all i need to do is buy speaker wire? and a wiring kit? does it matter which one? and about the static... when i turn the fad to 0.. theres alot of static in my speakers.. but if i turn it up.. then its fine
xxsenceo89x
aka superman
is it comin from the back of ur head unit or from speaker wire? if its speaker wire get bass blockers. if not the speaker pos/neg r touchin
xenoicity
Honda Technician
is it an aftermakert head unit?
maybe i should put it this way... no matter what, u need to buy an amp wiring kit, this usually consists of a low gauge (thick) power wire with a fuse that should be placed close to the battery of the car. It should also come with a higher gauge (thinner) wire that is used as a remote (to turn on the amp when it recieves a 12V + signal). it should also come with a set of RCA cables to hook the amp up to the stereo.
to install the amp, you should drill thru the firewall and wire the thick wire with the fuse close to the battery. but dont connect to battery until you are completely done with everything. this power wire should be wired to the 12V-input on your amplifier. this is the step you need to do with every amp. also dont forget to wire the amp to a good ground source in the trunk or chassis.
For an aftermarket head unit, there should be RCA AMP outputs on the back. all you need to do is conect the rca output from the back of the head unit to the rca inputs of ur amp. and in the wiring harness that attaches the honda harness to the stereo harness, there should be a cable that says "remote out". you need to connect this cable to the thinner rremote cable from the amp wiring kit to ur amplifiers "remote". what this does is when ur stereo turns on, it sends a 12V signal to ur amplifier simply put.
i hope this helps out
chadi
chuatZ
with all that static...i think you are turning you head unit too high...
or the speakers are ripped...
