options, options, options.......
5thGenCX
long gearing owns me.
Okay, here's the deal. Birthday's coming up, and with the job i'm getting, i'll have some green. I've been thinking about what would make the car faster w/o spending a hell of a lot. Here's what ive come down with:
SOHC 16-valve 1.6 liter head from a CRX or 6th gen civic
92-95 EX/Si manual tranny to replace my POS CX tranny
As far as VTEC heads go, i'm not a HUGE fan of VTEC, I see the benefits of it, but maybe later on I could swap a VTEC head in, since there would be other things to do, such as hook up the VTEC wires, put a new ECU in, etc, which I dont have time for right now. Anybody have any other suggestions for cheap performance gains?
tonyM
caca poopoo
youre not a huge fan of vtec? WTF? i dont get it :wtf: besides if yer limited on cash you can always get a j-spec zc motor and you'll smoke coupe SIs,youve got a cx ,thats the lightest of that year. its not hard to make that car go fast.plus the zc motor just drops in,all you need is a p-28 ecu a new o2 sensor and wire the vtec and yer set.
DirtyD
#1 don't take an engine out of a 6th gen because you have to worry about a wiring harness for obd1 - obd2. Get a D16Z6.
#2 dont take an engine out of a CRX because you can't convert obd0 - obd1. Again, go with a d16z6.
#3 you can buy a z6 for about 450 with tranny and if you have an extra 1500 you can turbo.
PS: do not, i repeat, do not swap in a non-vtec engine, there's no point. A VTEC engine is about an extra 100 dollars for about 20 hp.
DirtyD
yea how can you not be a big fan of VTEC? It's blasphemy.
bcivic94
like it was said before just get the d16z6 not only will you get vtec but also the tranny your looking for. all for the price you can do a complete mini-me swap for. if you can get the engine and tranny for around the price dirtyd said before.
mymmeryloss
RHD is where its at
the only reason not to get VTEC is if u r turboing a B-series(for compression purposes).
anfrey
OG スバリスト
get the ZC like tony said... it comes in both SOHC and DOHC variants (and yes, it is a dohc d-series engine)
DirtyD
That's also a good idea if you're looking to spend a little more money. If you do have the money though go with anfrey's idea.
anfrey
OG スバリスト
it's tony's idea, not mine :P
slammed_93_hatc
NoR*CaL knowledge b***h
actually thats wrong, if you have a good tunner they can handle 10.xx:1 compression no problem. but if your tunner sucks then thats were you run into problems. higher compression lets you make more HP. the lower the compression ratio the bigger room for error there is.
Sound Streamin'
Boost or Die
Don't like vtec???? Clearly you've either A. never owned a honda with it, or B. never even driven in one with it. vtec is worth every penny... hell on a d series it's not expensive either. get it.
Handlebars
None Taken.
im not a huge fan of vtec either. but the sohc vtec motors are built far better than the non-vtec versions. if going with a sohc, get the best engine in the correct obd.
slammed_93_hatc
i used to be in the same boat as you guys saying you didn't like it but, after seeing b18c5 stock and b18c1's moded dyno charts they kick the ever living hell out a a ls motor from the get go to red line, how ever b16a' thats a different story
