Straight forward install, pull old seal out clean everything up good, use seal driver and install new seal flush with housing. Used sil glyde on the inner seal lip so cv shaft would go in nice.
Most I have talked to said they have installed aftermarket seals which all leaked and went back to oem and they worked. Pulled my first seal out and it looked perfect
Have not replaced the bearing and dont seem to have shaft play.
