Over boosting
slammedSI
ok let me start by saying that i have been builing honda motors and racing before i had my licens. I own a performance shop and know quite abit. well wiht that said, my 00 SI, LS block and b16 head is over boosting. i have tried to find the problem but with no sucess. i have looked for vacumm leeks, holes in the exhaust system, the turbo is less then 6 months old, the same goes for the wastgate. i cant seem to find why its overboosting. the wastgate is suppost to hold at 6psi but wants to climb bast 10. i dont have it tuned for past 12 so i cant let it get that high. i cant floor it because it will just keep building boost. so what dose CC think can you guys help me out?
Bob.
silvertuner98
personally id check to see if ur wastegate rod isnt possibly bent not allowing the wastegate to open up all the way. then id go ahead and replace the 50 cent hose controlling the wastegate
slammedSI
all new hoses to and from the wastegate, see the thing is the car has been setting for 2 months, in that time its been driven maybe 4 times not farther then 5 miles. i know the rod is ok but whats strrange last month the car boosted fine, but now its over boosting, it boggles my mind. there couldnt have been any thing happen to a car from just setting for that short of a time could there?
bizoneoeh
Ex-Gang Member
Yeah, that's the only thing I can think of too the wastegate rod :???: it has to be something with the wastegate I say
what kind of turbo and wastegate do you have?
btw, welcome and post some pics :welcome:
silvertuner98
its going to be something simple that is overlooked. without having the car infront of me i cant hardly tell. all i know is "i have been overboosting, whats the deal"
slammedSI
its a greddy kit (TDO5-18G) i cant think of why it would over boost like that. i was thinking if i cant find out what is causing it i will just turn the boost down via the rod on the wastegate.
thanks for the welcome. i have many project cars so i will be asking for a lil help alot of the time lol. im the same guy that has the 00 si that made 422whp i made a thread about it a while back.
Shiznit
Stickin it to the Man
slammedSI said:
hey i just wanted to stop by and say hello. I am new to this form but i have been a member of clubsi and 7thgencivic for about 2 years. I would like to make this form my new home if thats ok. I drive a 2000 civic Si that is boosted, i guess i can give you some specs. The motor is a LS/VTEC, the turbo is a GT35R it made 323WHP @ 13-14 psi, and 422 WHP @ 22-23. the rods are eagle H-beam ( I know there going to give out) aris pistons (9.5:1) , blox turbo cams and skunk 2 valve train.the head has a three angle valve job. the crank is knife edged. Thats pretty much it for the basics, if you like to know more just ask, I'd be more than happy to answer.
Shiznit
do you have a manual boost controller? thats the most common problem with boost spikes
slammedSI
not as of now im rinning just the wastegate, i just took it around the parking lot and i noticed that the bov is sounding weard. Its a greddy type-rs but it sounding like a hks ssqv for some reason, its strange i just noticed.
Evan.
iTrader EVERYthing
check for leaks?
bizoneoeh
Ex-Gang Member
I don't know, boost leaks will cause you to loose boost. I had a boost leak and everything sounded weird, I was only going up to like 5psi and that's it. I still say something's wrong with your wastegate but then again, what the f**k do I know? :lol:
slammedSI
im right there with ya buddy. i have no clue and im so f**king lost, i have a few extra wastegates, i guess i will try to swap it out and see what happends. i will update later with how it go's.
bob
sohclubkid
Sick 6/6
since u say its been sitting, maby the wastegate is sticking... just my thought...
slammedSI
you know i was thinking that cuz the weather has been very wet here in fort worth the past few days. but i took off the wastegate and put a new one on i had at the shop, but its still boosting past 10 psi. The only thing i can think of to do is to turn the boost down via the wastegate rod, or put a elec. boost controler on it and see if that will work.
sohclubkid
Sick 6/6
yea... if the wastegate os not stuck, then it probably needs to be set up better... i would get an EBC for it, and double check vacume lines/ routing.
slammedSI
i was thinking about just going external wastegate. maybe that will be better. all my other cars are external. what does CC think?
