civic1995
Hi, I have civic 1995 coupe. The car overheat every time when I drive it or when its park and running. I took it to the mechanic and he told me that the water pump was licking so it needed to be replaced, he changed that and timing belt, but theproblem wasn't fixed. He checked the car again and he said that could be the head gasket, then he did replaced the head gasket and replace the old thermostat. but that didn't fix the problem, then he decided to flush the radiator and check the hoses, he told me that everything is working fine and the car should no overheat, I took it for a ride and the car overheated again. I brought the car back and he checked the fan if it was working and it was working fine. he doesn't know what could be causing the problem so I have no idea what should I do with the car.
Thanks in advance for any advice
