After a leisure 50-60 mile drive the other day, my temperature gauge began to climb up to 3/4 of the way. It normally operates at about 2/5 of the way. I turned on the heater and I was able to drive home with the temp. needle at half. I verified there are no leaks anywhere and there is no foaming in the oil to indicate a potential head gasket issue. Once the engined cooled down, I checked the fluid to find it was a bit low so I filled it up. Since then Ive driven it & it seems to warm up quicker than normal. After about 15 minutes it starts to climb again. I just removed the radiator cap and ran it for 30 minutes with the heater on full blast and it stayed on the low bar of the gauge. I then turned off the heater for another 20 minutes and the gauge leveled off at about normal. The fluid did not fluctuate either. It seems the radiator fan never kicked on in the many times in inspected the process.
Thus, I'm leaning toward the issue being either the fan motor or fan relay. If it is the fan motor, is it worth replacing or should I consider upgrading the fan altogether? Please let me know if there's a way to verify one or the other being the issue. Your expertise & suggestions will be appreciated.
