P0505 - D16y8
Chriscivic
Hey all I got a p0505 code and I've tried checking other posts but can't find the solution.
I replaced the IACV with a new one from Honda and no luck.
I adjusted the idle through the set screw and air mixture screw no luck.
Tps was properly calibrated and no luck. The car has trouble staying idle when cold, I have to give it gas to stay idling. When the code pops, the idle is erratic and idles around 1200 Rpms.
I was just driving down the road and my thermostat was going little over mid way and back down and back up and back down.
I'm running a skunk2 manifold and skunk2 70mm throttle body.
Thanks for the help.
Chriscivic
This is the only code thrown. It returns after resetting. Thanks
Sleeper0
Try burping the system you could have some air trapped and need to get them out
Chriscivic
Yes, low idle when starting in morning and then higher idle when it warmed up.
I burped the system again, car thermostat is good now. Although I still get the code, I sprayed the throttle body gasket and it changed the idle speed. Would a throttle body gasket leak trip this code?
Ep3po
How long ago did you do throttle body mod? Did you have this problem before the mod. I would expect that it is the junk2 tb causing the issue.you didn't buy it from eBay did you?
Chriscivic
Hey, thanks for the reply.
I got the car after an auto to manual swap was half way done with it, and I had to swap to the 2 wire iacv due to I had to purchase the new harness and ecu. In a jam I ordered the skunk2 intake mani and throttle body right from their site. The throttle body gasket was replaced, and that resolved the low idle in the morning, and it seemed to resolve the problem for the most part. Although I don't believe I am there yet to say my problem is completely solved.
At low rpms and drive in 1st, the idle will surge a little bit. Just a little.
In the morning the RPMs sit at about 1800 rpm, then drop down to about 1000 and I believe it's just because I need to drop the idle down a little bit more.
I do notice though that when I turn my heat on, the idle jumps from 1000rpm to 1200rpm. Is a 200 rpm jump normal when the heat is engaged?
I'm going to drop my idle to about 700rpms, I believe that's about where it should be.
What are the issues I'll see from when I set my idle, I fail to unplug the IACV?
Update: today we have beautiful weather here in New York State, about 60 degrees out. My let my car warm up and it's currently idling at 700ish. Why such a durastic change in the cold?
Thanks
Ep3po
What year is the car? Sounds similar to a problem I had with a old Acura legend years ago it ended up being cracked vacuum lines it would throw the pgm-fi lite on the dash and idle very high like 2000 rpm or so. And was more of a problem when it was cold out than in the summer.
Chriscivic
The car is a 97 civic ex with a y8 in it, I've been driving it today and she's liking the warm weather right now haha.
Chriscivic
Code popped again yesterday, Started to idle at 1500 then popped the code. I unplugged the IACV, and the idle dropped down to 900.
I reset the code, left the IACV unplugged then reset the idle to 500 RPM.
What issues would I face if I was setting the idle with the IACV left plugged in?
Cold air = more dense air = more fuel required to compensate. In order to better warm the car, the ECU controls the idle when cold, and won't use O2 sensor feedback to control the A/F ratio until the ECT reaches normal temperature.
As for setting idle speed, you want to set it with everything plugged in, not left unplugged. IACV included.
You mentioned earlier that you sprayed around the TB gasket and the idle changed? Sounds like that's your issue.
Chriscivic
Hw
i ended up replacing the throttle body gasket, and that fixed the low starts in the morning, and reduced the amount the time the code pops. Although once in a while it pops
Chriscivic
1997 civic ex manual
Only aftermarket s**t on it is the intake mani and throttle body which are both skunk2 and yes tb bolts were torqued
Ep3po
Like I said above 10 days ago I think it's the throttle body. Do you still have the stock tb on hand still? If you do pop it on there and see what happens.
Jersey8
B20: Detroit Muscle!
Did you put on a new manifold gasket when you replaced it? Sounds like the gasket is not sealing 100% in the cold, but is expanding in warmer weather and filling the voids. This would explain why your car runs better in warmer climate.
