Green 91 said:
I am not sure if you understand that or read it or are you confused. The only version that can be chipped is the cali version and it is identical to the P06/P28 board. The other ones have 2 processors one for the engine functions and the other for the wideband, atleast that is how it was theorized.
The regular version can be chipped, but you can't use uberdata/crome or anything like that with them. If you good at manipulating hex code, you can modify it yourself. Then yes, you could use it. But it is way to much hassle.
