Paint help
Oem>
About to paint my 00 front end because it is primed at the moment. The Color is Milano red and going to use Duplicolor Color match. The Question is How many coats of color and clear are needed and what clear should i use (brand wise)? Read somewhere that its a Tri coat so would i just spray 3 layers with sanding inbetween?
CivicEX13
CC's Valve Cover Guy
3 stage mean just what it sounds like color then mid coat then clear but you can get it in just base clear a fit is hard to say you put color on till it is covered could be 3 coats could be 6 lol
Oem>
Sorry but kind of lost me haha. Spray it untill completely covered, wait till dry then sand x3 then clear?
Trekk
For starters rattle can paint lays down very thin, so you want to do as little sanding as possible. Now to make paint look decent the first thing you need to buy is a 3m maroon pad. Most auto parts stores sell them in a 3 pack. Next softly scuff the surface you are going to paint with the 3m pad, this gives the paint something to hook to. Next spray the color, coats doesn't matter, you want full color coverage, meaning paint it till it all looks the same. Now for the tricky part, if it's a metallic color you need to paint in lite coats. If you go to heavy the metallics can sink in the paint, and it won't look right. If you need you can do a final fog coat where you spray from a larger distance this help lay the metallics right on top. Next let it dry then you can clear over it. If its been drying for a day you should scuff it up again with the 3m before you clear.
Really the only time you sand between coats is when you did a crappy job with the last coat you painted, or it has been like 8 hours since your last coat of paint.
Oem>
I have a 3m wetodry sandpaper "kit with the toughest grain being p400, wold that work?
Trekk
You could use the 1500 grit in place of the 3m pad, but the pads do a better job on bends and what not.
