Parking Light Wire 98 Civic CX Hatch
mongerson
I've read from numerous sources that it is the red/black wire in the passenger kick panel. The problem is there is 2 different red/black wires in 2 different harnesses. One harness is green the other is blue. The green one is mounted on the ECU, and I'm guessing thats the correct one. Any feedback would be appreciated.
GTIUNIT
very yes...
you could also find the park light wire in the radio harness or the at the dimmer switch.
piston
Slow Box Driver
if you have a multimeter you can probe the wire and turn the lights on, if your voltage goes up to 12v or higher, you found it.
Jason
loccusst
Experienced Noob
Why oh why are you in the pasanger kick panel? LOL Go to the otherside of the car....MECP already listed everything from the best source out there. Do you know how to operate a DMM....NOT a test light. If you don't have a DMM then go get one.
