blueclaws
Hi Guys,
I am the proud owner of a new (to me) 1999 Honda Civic Coupe EX. I'm trying to get to the bottom of a problem I am having with the passenger door lock, and hope you can help. I did a search on these forums already. No aftermarket parts on the car.
Inside the car: both driver and passenger door locks manually open and close OK
Inside the car: both driver and passenger door locks automatically open and close OK with the power switch
Outside the car at the driver's side with key: both door locks automatically close OK, but only the driver's side lock unlocks. The passenger door does not unlock with key.
Outside the car at the passenger's side with key: passenger locks open and close OK.
Because the passenger door locks and unlocks via the power switch on the inside, I believe the actuator is OK.
What do you guys think is causing the passenger door to not unlock at the driver's side with a key?
Thanks in advance,
-Peter
Thanks in advance,
-Peter
