canadian_l3acon
Hi there, I am in serious need of help. I have done alot of working on this passenger window and still no luck. Its a 1998 Honda civic EX 2 Door
I have done the following:
- checked possible blown fuses
- checked continuity at the motor for 12v (it reads 12v on both depending on which way the switch is engaged)
- replaced Motor and Regulator
- then checked if the Motor and Regulator are working both and the new unit and one previously installed, both work fine.
- replaced master switch driver side, still no luck
The driver window works fine, passenger window does not show any signs of power. I am thinking its a ground issue, but all the plugs in the master harness are in there fine (not loose).
Would I be correct in thinking its a ground issue?
