Buttaz54
I bought this 92 Civic that was converted to 5 speed. I have a power window problem. All windows work except my passenger side window. I can roll it up, but not down. I have tested the switch, motor, and regualtor on the back passenger window and it all works as it should. I replaced the wire harness in the passenger door and get the same results. I most recently replaced the driver side master switch, but I get the same thing.. I noticed that there were a couple wires cut on the driver side for the power window switch, but I wired it and still nothing. I've replaced fuses. What else would be causing this..?
