Passenger Window 2dr
PhntmSk8r
H23VTEC
Ok so the other day i was washing my car, rolled my winjdows down, pulled it into the garage to wax/polish, and then i got in after to clean the windows, and the passenger side wouldnt roll up from the driver side, however it would roll up from the passenger side, but not down.
ok.. so
NOTHING for the passenger window on the drivers switch works
the passenger switch will roll the window up with the door closed, but not down. However, if i open the door it will roll up and down, but only from the passenger side.
so... wtf?
ImportFan1
Super Moderator
that is what you called f**ked up my friend. sry. i really dont have a clue what the issue is. short somewhere?
PhntmSk8r
H23VTEC
I pulled the fender, and traced all the wires through the boot that runs from the door to the chassis and none of them are broken or have the wire exposed...
I dont know where else to look?
Theoretically if the passenger side switch has full continuity, then the drivers switch should work, thus meaning the drives switch should work when the passenger door is open, correct? (since the passenger switch works with the door open, and the window rolls up/down fine)
ImportFan1
Super Moderator
i honestly dont have a clue how it works. maybe its a bad drivers side switch?
PhntmSk8r
H23VTEC
bump...
i still havent found a resolution to this problem.
The passenger side wont roll up or down, unless i put power DIRECTLY to the motor from an outside source.
kaace
I'm getting there...
sounds like a bad drive side switch...ask honda is they have a working one you can buy...swap out...and return if its not the problem...
what is honda's policy on returning electrical parts?
PhntmSk8r
H23VTEC
i was thinking the same, but ive been holding back because i priced one and it was $184 :shock:
kaace
junk yard? pick and pull? a friend with the same type of switch?
