soo i plan on running a turbo soon but when i do what do i need to do with my PCV system.....can i just stick a breather on the valve cover and run it like that for a while????
Sure, it doesnt really become a problem until you start throwing some serious pressure into it so, it will be fine like that for a while.
i too speak from first hand experience. i've been boosted and self tuned for 3 years now.I don't know, I have seen these posts before and all the explainations but what I do know is, I have been running like this for 4 years and still going. I do compression checks every 6 months and the last was 215 across the board from 218 before I started boosting.
I'm not going to sit here and argue who's right or wrong in theory you are correct but through my experience, the filter is working just fine for me at the moment.
Ok now I am interested.i too speak from first hand experience. i've been boosted and self tuned for 3 years now.
here's the easiest way to think about it. The pcv valve that's in the black box on the back of the block is inplace to prevent any positve pressure form the IM getting into the crankcase. however, if you just run the stock valve in a line *thinking* that it means it is vented, what is actually going on is the valve has a cracking pressure. a very small cracking pressure like .3psi but that is still .3psi that has to build in your crankcase before that valve will let it out.
i'm not here to argue either, i just want people to have the right information.
easiest setup is to pull the pcv line from the im, cap the nipple on the im, and yank out the pcv valve. bam. there is a "vented setup".
add in a catch can, maybe a drain back feature, and some creative ways to add vacuum sources and now you're talking a real crankcase ventilation system.
i'm happy to help where needed
-Luke
here is my ideal setup. it has a vacuum source at all times, and has check valves to prevent reverse flow. the line to the IM is double filtered. the vacuum sources work at opposite ends of the spectrum:Ok now I am interested.
I am going to be going back to the dyno after my current completion of upgrades to get more tuning in cause it was cut short last time because of a wastegate issue. What would you consider the ideal set-up? I think I would like to try it and see if there is any improvement in power. From alot of what I have read there should be an improvement in power cause of the oil contaminating the air/fuel mix in the combustion chamber.
From the lot of breather systems or catch can that I have seen Endyn's seems to be the most complete. Do you suggest that one or something other?
