pistons and rods ?
Oz_Vtec
WOuld b16a2's pistons stand to Turbo operation. Would the pistons have a damage?
Would high compression make a problem?
What is the limit of pistons for maximum psi?
SeanMc300
professional a*****e
your compression is fine, dont need to move it one bit. your rods and pistons will take u to about 9 daily. if you have the cash its not a bad investment but DO NOT lower your compression, your compression is fine...it does not need to be altered.
SeanMc300
well i dont know about the b16 but im imagining...with proper fuel..........12psi... i know a kid with a d16 who runs 9-10 daily on stock internals for almost a year....no problems. if you are gonna go 10 daily...id get a hondata ecu....just for proper fuel. tell them what you want to run for psi, wha tyou have and size injectors....they can definately tune your ecu to the correct shiz....
Oz_Vtec
i have Greedy e-manage system and 440cc injectors
are these enough ?
SeanMc300
on your d16?? id go with the safc hack and some dsm 450cc injectors.
SeanMc300
s**t...i meant b16....my bad. still, screw the greddy...either run the safc hack or get a hondata
blownhatch94
got boost?
yeah 440 injectors and hondata will make sure u run safe. id say 12psi would be the max on stock internals but i wouldnt run 12psi as a daily driver
Exospeed*com
exospeed.com
You can have all these proper ECU and injectors, but what will matter the most if the setup is tuned right. All it takes is one time that the motor runs lean and it can ruin the engine. but with a properly tuned system... your motor can withstand the turbo setup for many years to come.
SeanMc300
right, and the greddy piggy back isnt a very good unit.
1.6 TURBO
Hey Oz,
I'm new to this forum, but has been running a b16a2 JDM engine for about 2 yrs as a daily driver with no major problems yet...just be sure to fuel your engine right...and get a pyrometer to chk your exhaust temp. about 1400deg max you should run anything over and you might break the engine...I am using a Apexi VAFC to control fueling...and to stop that chk light you will need a proper check valve before your map sensor...
JDM James
Ominous
Agle?? You mean Eagle?.... never heard of Agle before, thats all.. Arias pistons own j00!
1.6 TURBO
Sorry my bad "X" its a b16a not a b16a2...in fact i'm from the Island of Trinidad in the Caribbean and its the first time I noticed that engine code b16a2...must have been in my mind...lol
SeanMc300
keep the stock compression and just get stronger made pistons....you dont need to lower it at all
JDM James
Ominous
JE gets owned by Arias Pistons, 9.0:1.
1.6 TURBO: its ok mistakes are made =) no one is perfect
