Em1Lifestyle
Plan on putting type r pistons in my B18B1 block would they go in or would I need to get my block bored
i'll say 10:1-11:1 is pretty good CR from most buildsThey are the same diameter if you get the OE standard piston. Just beware that you are about to increase the the compression to about 11.1 depending on if you use US P73-A0 pistons or JDM P73-00 pistons. The JDM variants will result in a slightly higher compression of about 11.6
true but for b series its pretty easy also regardless of what head hes using the difference is ver minor b18 non vtec head has only 45.0 of cc while all other b series vtec head area ll 42.7 of cc only 2.7 differenceThat's cool.
We also have no information regarding his head choice, valve train, and cam shafts. Hell, we don't even know what this engine is being built for.
My last NA build was 11.72:1 on 93 all day every day. Never had any detonation, I still have the pistons for any future builds I do. Pulled that motor and parted out some of it to put in a freshly boosted motor I built about 3 years ago.i'll say 10:1-11:1 is pretty good CR from most builds
yea i'm just surprise that the Honda starting to get on board with high compression turbo builds when domestic people been doing it for decals now... but my setup is custom cause there really not much of "off the shelf" parts like the b series it take all the math work out the initial stage of the build i have wiseco custom 85mm with skunk2 alpha k20a/k20z rod in my f22b1 block which also is paired with my built h22a head. lol so my motor is F/H/K series as one motor. 9.75:1 was the best i can do my actual target CR was 10:1 unless i bore my sleeves to 87mm and use h23 rods plus if i used stock rods my CR woulda been 11.75:1My last NA build was 11.72:1 on 93 all day every day. Never had any detonation, I still have the pistons for any future builds I do. Pulled that motor and parted out some of it to put in a freshly boosted motor I built about 3 years ago.
