That's exactly why I'm getting them. So is there a clear consensus that projector headlights are crap? That's why I'm on here asking which stand out above the rest.
If you run 35w HIDs, then you should be fine with any old projectors.They may, however, have leaking or hazing issues. I would recommend using some silicone sealant along the entire sealing edges to prevent moisture and using clear coat on the lenses to prevent hazing.
If you plan to run 55w HIDs, then those projectors you can buy will melt. You'd need to retrofit some projectors from an OEM car.
Whether you plan to run 35w or 55w HIDs, your stock headlights will be fine. The scatter isn't too bad, but it doesn't look like OEM. I have 55w 6000k HIDs in my stock headlights and love them. When aimed properly they don't blind other drivers badly.
Here are some pictures of my 6000k 55w and my friend's 5000k 55w.
If you have any more questions, please let me know.
