I was looking at pics of intakes on the d16 and I came across one with a power chamber intake on a d16. My question is where would the three sensors that plug into the stock intake plug into on the power chamber .
Then what about the the other senors that are plugged up to the stock intake arm?If it's only an intake you only need ONE sensor, and it's for the MAP sensor, that's the only sensor on the intake it's self!
Yes I know the MAP sensor is on the throttle body not the intake tube. If put a breather on to replace the hose that's goes two intake arm what do I do with the other two hoses?Wow
One should be for the breather off the valve cover
The other should be for the IAT, IIRC on d16y8s it is plugged into the intake tube and not the airbox
the MAP sensor is NOT on the intake tube
