Power door Conversion Question on 98 coupe
19civic98
SiR coupe?
Crashed not too long ago and it broke the trcks inside my driver door on my manual window, So i want power windows anyway. I found 2 99 Si doors without windows for 150 perfect condition, My question is hard hard would it be to swap the windows and install the doors with power?? and do I need anything besides the doors themselvs??
cleansleep37
t3EJ8
doors
I would imagine youd hafta run all new wiring and harnesses for the power to the doors. the doors themselves will have harnesses, but your car wont if it was manual before. good luck with that, Im sure you could find used ones at a junk yard and look up the installation instructions. Have fun with that though...:shock:
TigBitties
Frame Bangin
Well im guessing you have a 98 based off your name, im not sure if the doors are the exact same. swapping windows in will be easy. But you will need more than just the doors. You will need the floor harness, panels, and switches. You will also have to swap the lock cylinders in the doors to keep you key. I did this swap to my car. Its not real difficult to do.
19civic98
SiR coupe?
the doors have the panels and all switches just nned wired, and how hard is it to swap the floor harness?
TigBitties
Frame Bangin
take the entire interior out. atleast windows and below. Then just unplug and swap. pretty straight forward
