Shaffer017
Ok I had just baught a 89 civic 4 door with a d15 b duel point and I am having an issue that has me stumped so ill try and explain it the best I can and hope u guys can help me out. The previous owners had an issue that led to the main relay needed to be changed and now the fuel pump will not prime but I go to look at is yesterday it fired right up with no problem. So today I go to start is all of a sudden the fuel pump will not prime and only gets power to the connector at the fuel pump when the key is turned on for a second then losses power again (with key on still) but when we moved around wires on top of fuel pump it started to prime and started for about 15 min. Then died out again and won't start again now. Any help would be great I know it's not fuel pump cause when it gets power it will start it's just not getting power to the pump thank you for your time .
