Power Window Problem 97 HX
slapah0
My passenger side window is not working in my 97 HX coupe. I have checked the fuses, and replaced the whole window motor and regulator, still not working. I know it's not the switch because it doesn't work from the drivers side or the passenger side. Has anyone else had this problem? Should I try replacing the whole passenger door wiring harness? That's the only other solution I can think of. Please help! I don't want to ride around with my window taped up any longer! :(
I should also note that I have issues with the passenger side lock as well. It only auto locks/unlocks when it wants to. Maybe the problems are related?
djmanning
sounds like u havea short in the wires some where pull the wires out a check them. work your way back towards the fuse box. may be a loose wire or ground...
