Hi everybody, it has been a long time since I used to be active on the forum but today I have some problem with the fuse #24.
Last night I passed over a little bump and the car shut down, so I towed the car to my house, today in the morning I checked the fuses and only fuse 24 was blown, I raplaced it and it blows when I turn on the ignition switch, so I checked the under dash wires, I simply moved them, replaced the fuse and the car starts again.
Two hours ago I used the car and again on a bump it turned off, I have checked continuity between the two fuse terminals, it has continuity only on the bottom terminal even when the ignition is off, also I removed the main relay and the fuse doesn't blow, but as I connect the relay the fuse blows, I think there's some short circuit between the main relay and the fuel pump, but I don't know how to diagnose it, or where to start looking.
Could you guide me on the right way?? am I right with the short circuit??
