alex_n/a
stocker
I've searched for a couple hours and have only gotten more lost
I swapped a auto d16y8 intake manifold on my y7. I used my y7 throttle body with a y8 rotor. kept the y7 throttle cable. everything else stayed y7. lower intake gasket also y7. I blocked off the cruise control nipple. iacv nipples are connected as they should be so is the pcv and evap. I used the y8 throttle body gasket by accident. I will be buying a new y7 gasket tomorrow morning. I have adjusted the throttle cable properly. reset the ecu a few times. all wires are connected. I am running a short (hot air) intake right now. I just put a cone filter as I plan to go turbo soon.
My problems are depending what i plug or don't plug.
version 1. I plug everything in as i think it is. car backfires and misfires. drives okay. cel will flash and turn solid. repeats. rough idle or hunting idle. i suspected the tb gasket and bad iacv. for the idle issue.
version 2. I unplug iacv and the other plug that is the same. I believe its the maf sensor. rough idle high idle. runs rich. does not do the hunting idle. not sure about the misfire. if any its worse on version 1.
version 3. I plug everything in but switch the plugs on the iacv and maf sensor. the car will idle okay. quick jerks to the trottle cable make it rev quick and correctly. slowing increasing the idle will bog out. basically will choke itself to death.
I worked on it all day and need the car for work tomorrow. should I make a quick trip to the autoparts store tomorrow and get a y7 tb gasket and have them run the codes for me for all 3 versions to see what info i can get?
my problems appear to be related to either the maf sensor or the iacv. except for the misfire. i don't know what to do about that. it has new plug wires and spark plugs. should I buy a cap and rotor?
