problems at idle ......help
luis monsalve
ok guys hope some1 can help me . i turbo my car , i got a 255 forced induc. fuel pump made by holley , i got a vortech fmu 12:1, i have no vacc. leaks am getting new plugs but it idles really bad i dosent stall but it feels like is going to. i drove it under boost is fine is just at idle ne1 have clue? thanx
Ravage70
list ur entire setup
ur most probably running rich
luis monsalve
heres my set up t3,vortech fmu , 255 holley forced induction fuel pump, adjustable fuel press. regulator, missing link thats it really am only running 5 psi 0f boost .
edhgreatone
i've have heard about this problem over and over and everytime i read up on it people says there is either a leak or your running to rich?? I wonder what causes this?
luis monsalve
well now it idles fine i lowered the fuel pressure and it idles perfect the next issue is after i boost when i come to a stop it does the same thing i can berly take off feels like i have a bad valve but is not am wondering if its still running to rich ?
help anyone
Ravage70
ur probably still 2 rich at idle
but ur real problem is what u chose as fuel managment
an afc with bigger injectors would be much better than an fmu
the ideal would be for u to convert to 0bd1 and run uberdata
evan2
Search owns you
if you ran rich you could of fouled your plugs easy, why not new injectors
granted you have a small turbo but your pushing more fuel through stock injectors still
and yes get rid of fmu it is junk...
