there is a little 2-pin plug on the passenger side tucked up next to the glove box. (the one you found) pull it down and then jump in with a paperclip. then turn the ignition to "on" (dont start the car) the cel will flash the codes to you. a long flash is 10 short flash is 1. like...... long-short-short-short would be code 13.
here you go. the arrow points to where the plug will be resting under the dash. there will be two plugs there. a 2-pin (circled) and a 3-pin (crossed out) you need the 2-pin.
Here is the list of codes.
0 Engine Control Module (ECM)
1 Heated Oxygen Sensor (HO2S)
3 Manifold Absolute Pressure (MAP Sensor)
4 Crankshaft Position (CKP Sensor)
6 Engine Coolant Temperature (ECT Sensor)
7 Throttle Position (TP Sensor)
8 Top Dead Center Position (TDC Sensor)
9 No. 1 Cylinder Position (CYP Sensor)
10 Intake Air Temperature (IAT Sensor)
13 Barometric Pressure (BARO Sensor)
14 Idle Air Control (IAC Valve)
15 Ignition Output Signal
16 Fuel Injector
17 Vehicle Speed Sensor (VSS)
20 Electrical Load Detector (ELD)
21 Variable Valve Timing & Valve Lift Electronic Control Solenoid Valve (VTEC Solenoid Valve)
22 Variable Valve Timing & Valve Lift Electronic Control Pressure Switch (VTEC Pressure Switch)
23 Knock Sensor (KS)
30 A/T FI Signal A
31 A/T FI Signal B
41 Heated Oxygen Sensor (HO2S) Heater
43 Fuel Supply System
if the srs is flashing then you have a problem with your srs system. ill see if i can find the codes for that as well.
