PS2 No Sound
OTownBling
Bling Bling
So i got a Audiobahn 7" TFT LCD Screen yesterday Put the PS2 in the floor board hood it all ap adn it works fine i can see the video but the sound is realy low is that because my CD player dose not have RCA input jacks or the Auxeliry Button?
PLz help
1999stockaccord
Honduh's... LULZ
what cd player do you have? does it have ANY kind of inputs?
OTownBling
Bling Bling
FM Transmiter??
I dano what that is but i went out and got a FM Modulatior maybe the same thing i dano but it dosnt work any way so i took it back
PIONEER CD Player only 2 years old mybe No there are no inputs 3 left and 3 right ones tho but thay are all outputs
Dr.Anus
proctologist
Usually you have to buy an input adapter seperatly. Check out ebay, they usually cost about $10 plus shipping and make your cd changer uplink on your head unit into audio inputs. It's not a hack or anything, the manufacturers just make it that way. I had a pioneer deck and after adding the adapter the unit automatically recognized and allowed me to switch to and tweak the audio input mode.
black97civic
black97civic
OTownBling said:
I have the second one for my pioneer. Yours is the second one also because it's a pioneer IP Bus connector. It basicaly plugs in where a CD changer would plug in on the back of ur deck. Do you know the model # for your cd player?
1999stockaccord
Honduh's... LULZ
:werd: thats what i used for my satlite radio
your headunit should have a BLUE rectangle IP BUS in the back
To be able to select the AUX input, you must turn off the pioneer deck, hold in the FUNCTION or display key for about 4 seconds and scroll over to AUX input, the default for most units is off, switch it on, then turn the radio back on, and when you hit the source button you should tehn have 3, radio, cd, aux
OTownBling
Bling Bling
damn this realy anals me because i went and got on from best buy the last one mind you because thay are not going to carry them any more i plug it in last night nothing works so i took it back the is so Bull shyt know'n that all you have to do is hold the Button damn ths Sucks SO f**kin bad
1999stockaccord
Honduh's... LULZ
it should have worked, depending on the model cd player you have, READ THE MANUAL, or have someone else do it for you, dont blame us for your mistakes :what:
black97civic
black97civic
1999stockaccord said:
whats the model # i can probably get you one
Yeah Pioneer has so many different units and it's hard to tell exactly what you need to do without a model number. what he said is exactly how mine is. You have to turn on the aux input because the way the CD player is set from Pioneer it is off.
j_fukin_t
its easy to do on a pioneer, simply turn the unit off, hold function for like 3-5 sec and a menu will pop up continue to hit function until you get to aux and simply turn it to "ON" then hit the source button and turn the radio on and hit source until you get to "aux" and wala your done, i believe the input cable is cd-rbd-20
*edit* just read that someone told you what i just did OH WELL
OTownBling
Bling Bling
I got a new I-bus pice the aux in-put and did what you guys said adn not i have the Ps2 in the car thanks to you guys
