question for Ohms
black_radiation
tinted death
hey guys, k if i have 3 subs at 3 ohms per piece, how to i get the circuit down to 1.5 ohms independant of an amplifier. thanx guys
mymmeryloss
RHD is where its at
and wow, i should know this..
chris
mymmeryloss
RHD is where its at
i'm trying to think...gawd...
lol
chris
J32a2OwnsU
Resident Old Man
Damn I know this too. I forgot the equation.....
If you run those in parallel Im thinking it will be 1 Ohm load.... I dont think you will be able to break it down to 1.5
black_radiation
tinted death
ya well my boss is a cunt then lol, k well he gave me the one problem, 4 subs at 4 ohms each, 2 subs to a side, one 2 channel amp that has to be at 2 ohms. heres what i figured
black_radiation
tinted death
why the hell cant i find verbals name in the member list... wtf i was gonna PM him but his name aint in there :S as a mofo
wannabe
law abiding smog tech
thatverbal, i believe
black_radiation
tinted death
ah ha discovered it, its That(SPACE)verbal so: That Verbal. lol found it and pm'd him thx for what help you guys were able to give. argh, wut a bs task....
J32a2OwnsU
Resident Old Man
You changed the problem from 3 to 4 subs.. your diagram i correct i believe... I still cant find the equation however... sorry.
black_radiation
tinted death
no it was a different problem
i have 2 problems one was 4 subs at 4 ohms each 2 ohms at the amp, thats wut the diagram was for, but i wasnt sure if it was correct but i still havent figured out the 3 subs at 3 ohms per sub, total circuit resistance of 1.5 ohms
cujo613
ok here is the answer
4 subs at 4 ohms a piece can be wired
A. At 2 ohms stereo. Two subs per channell. All positives and negatives connected together
B. 1 ohm mono. All positives and negatives ran together with the amp being bridged.
C. Heres the tricky one. 4 ohm mono. Through series parallell wiring. Take two subs. Wire the negative terminal of one sub to the positive terminal of the second sub. This will leave you an open positive and an open negative terminal.
Wire the other two subs in that fashion. This will give you two sets of subs wired to 8 ohms. Bridge your amp to those two sets of speakers and the impedance will be a total of 4 ohms.
As for the 3-3ohm woofers you can not achieve a 1.5 ohm load. These woofers will only achive an overall 1 ohm or 9 ohm load.
Thats pretty much it and your only choices
