Questions on trubo my d16.
Schlingding23
Im thinking about getting edelbrock turbo kit, boost controller, upgraded spark plugs, and exhaust. But is there anything else i should get for my car which im about to turbo?
00civicsiturbo
addicted to Boost
injectors, fuel pump, clutch, wires... search my friend
bizoneoeh
Ex-Gang Member
what does the kit come with?
and you can't forget about the tune.
00 Coupe EK3
Some people may say you dont need it but id suggest a better head gasket say like one from Cometic and arp rod bolts and head studs
bud6770
Your mom has vtec
Depends on how much boost you plan on running, and the motor. On a d esries you can run 6-8 lbs stock, on a b series you can run 8-10 lbs. Anything over 8 lbs i would get some injectors, dsm injectors would work fine. You only need to start upgrading other if you plan on runnin over 10 lbs
ragedeep
lol i plan on doin the same to my z6, after searching, you realize its a short list:
first get a compression and leak down test. then add a cosmetic head gasket, arp head studs and bolts, t25 turbo @ 8 psi, blow off valve, front mount inter cooler,IC piping, bigger fuel pump, 370cc-450cc fuel injectors, upgraded air intake, a programmable or chipped ecu, 2.5" downpipe and better exhaust, steel oil lines, tap you oil pan, get a really really good tune, dyno if possible, find religion and pray that you dont blow your s**t. at least this is my list.
1Lowcoupe
Injectors if the kit doesn't come with it, hondata s300 is nice, or a socketed ecu tuned on ectune, neptune, maybe crome pro. I think the edelbrock kit might come with some sort of engine management though.
TiiM iiS l3eAsT
Scamming Piece Of s**t
wow....word of advise....dont go by psi....
stock d series rods can handle around 220-250whp...now depending on what turbo, it can be between 6-14psi.....
on a b series motor....stock rods can handle around 300whp....which again depending on the turbo can be around 8-18psi....
ragedeep
damn 200 whp? is that pushing it or is that in the safety regions? i know it all depends on the tune but im just wondering
s_crowley 17
there are plenty of single cams out there that are pushing 250 or at that point.. stock
200 is a good tune for a single cam..
ragedeep
damn not bad, man i cant lie, before you are completly sure your going to turbo you car, do as much research as you can, because even with a kit, you still need other parts, well apparently...
ragedeep
its even harder for me, i gotta find a pro rebuild kit for my tranny cause im going boostin on my auto tranny
