I have a 98 civic ex d16y8 with 198k miles. Lately if I drive for a while (20 minutes or more), I’ll get a very random hiccup/slight misfire at idle which is not predictable. Some days it never happens.
I have new spark plugs, wires, cap and rotor. When I replaced cap and rotor I noticed oil INSIDE the cap, I’m guessing from a failing internal seal. Not much it wasn’t pooling or anything, but enough to notice. There was no oil around the cap terminals or rotor so I’m curious if that could still interfere with ignition in some way and is what’s causing the random hiccup?
Also I’m wondering if loose valves would cause this issue as well (they were last adjusted around 100k miles) or since that’s more mechanical if the problem would be more consistent and not so random?
