Random overheat - nothing seems out of ordinary though
Modest Throttle
Did a search for this topic but couldn't narrow down the results to fix the problem.
Problem is, my car has started to overheat twice in the past month. The first time it happened after I was getting on it a little. I figured I had just heated up the motor from holding my gears longer than normal cause I stopped when the needle got close to red area, turned off the car, then started it up and the needle went back to normal at halfway point. So I forgot about it and it didn't do it again until yesterday. Yesterday it happened after I had to engine brake in 3rd then 2nd gears to stop quick at a light that turned yellow. Again, I stopped when the needle got closer and closer to the red zone and shut it off. Waited a couple minutes, turned it back on and it went back to normal just like the first time. I'm thinking thermostat needs replacing or I heard from a mechanic friend that it could be a fan relay? any input is appreciated
