SailorBob
I've got a 2000 Honda Civic iSR with the old 2+3 pin Honda DLC which I'd like to read ECU data from.
According to the Evoscan website the pinout for the 3 pin dlc is ISO 9141 K-Line, B+ and ground from left to right.
So I hooked up the K-Line to pin 7 on my ElmScan5, with power going to 16 and ground to 4. I verified I had the pins correct using a multimeter.
Now, according to the DLC page of the Hondash software cars with this DLC can be Honda OBD1 ( 92-95), OBD2A (96-99) or OBD2B after that.
So I figured that the car is probably OBD2B, so I tried the open source ScanTool.net software developed by the makers of the ElmScan5 but it wasn't able to communicate with the ECU.
So I also tried the Hondash software, but that also didn't work. Now it could be that the Hondash software only works with their own DLC connector they sell, and not with a standard Elm tool.
So I'm wondering if anyone might have any suggestions of software that will work with my current scan tool? I ran into a similar problem with my Mazda 323, and 626, which used either J1850 PMW or K-Line. I could use my standard OBD2 adapter, but needed special software like ForScan to understand the software protocol they were using; regular OBD2 software couldn't communicate with them.
